Object Import Scale (Mac)
I've looked through the forums and other sources trying to find an answer for my question with no luck. I recently acquired a Printrbot Simple Metal and I use it with the most current version of Repetier. I'm having a lot of issue importing STL files in the correct scale. I build my models in Maxon Cinema 4D, Foundry MODO and Rhino -- all using mm as the metric system. Every time I export STL and import into Repetier for printing, the model is extremely small. It is not picking up the correct scale.
I noticed that in the Windows version of Repetier you have the option of select the "Scale" for imported objects, but I don't see the option in the Mac version.
Is this a bug in the new Repetier? I've used the program for years with no scaling issues.
Please let me know if this can be solved!
Thanks!
m~
  • The mac host has no scale on import. It always imports 1:1. STL also has no units, so if they are not mm the exporter decided to not save as mm.
