Pick and Place
I want to use repetier to control 4 motors .... the idea is to pick and place ... 3 motors to control the axes and the fourth engine would control an air pump to collect items .... can you do with this program?
  • Latest 0.92 version supports 4 extra motor drivers which can be used whan not moving around. Eventually you need to add a extra motor driver depending on motor but with that I think you can mususe the firmwre for this.
