server crash: Error parsing version string
i installed the server (0.60.2) on a Raspberry 2 Pi B.
If i login to the web interface i always get a "Connection Lost" message after a few seconds.
I found a error message in /var/lib/Repetier-Server/logs/server.log:
"Error parsing version string <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">: Syntax error"
Reinstalling the server does not help.
Restarting the server does not help :(
  • The error message has nothing to do with this.
    The frontend connects with a websocket to the server. Everytime something disconnects it, you get the connection lost message and after a few seconds it will reconnect and work goes on. I hope this also happens for you.
    If it starts coming and going it might be a instable wifi connection of the pi. You could then test with cable connection to verify it is the reason.
    If not provide more informations like you os and browser type/version you are using. We develop it with chrome and have the least problems with that combination, also firefox and new IE also work.
