Slaving axes
edited June 2015 in Questions & Answers
Hello, I just switched from Marlin to Repetier, and I'm coming across
two issues. On my printer, I'm running an Azteeg X3 Pro board with a
ViKI LCD Screen. My printer uses 2 z-axis steppers, each with their own
controller, and I can't seem to find a specific line of code to allow
for slaving. My board is currently wired such that the pin layouts
should be: X, Y, Z1, Z2, E0, E1, E2, E3. This can be subject to change.
Any help with this issue would be appreciated.
My second issue is
that I can't seem to hand-jog my extruders. As this is a
build-in-progress, I don't actually have the heated ends ready for use,
so I'm just jogging the motors to ensure they work. Is this an issue
with the ViKI? Or do I have a setting set incorrectly? Thank you for any
assistance.
  • Fixed both issues by actually paying attention to setting up the configuration. Thank you, Repetier, for having an easy-to-use setup. I'll remember to read a bit in the future before posting.
