large span is not supported
I have a large span that when sliced within slic3r is supported properly, but when I click slice in repetier-host it does not put in the support, the span is at least an inch, it is also flat.  When I put and angle to it, it get the support, so when it is flat it does not create support when sliced through rh
thanks
  • Are you using the same slic3r versions and the same settings also for support? All we do is calling slic3r with your selected configs.
