Repetier cronology
Hello Everybody!
Does anybody know if  Repetier has a kind of "memory" of the latest works?
Yesterday I was printing an object, but suddenly the pc switched off and, obviously, so did the 3D printer. In order to don't throw away the part that I've already printed, I would need to find the precise line of the G-code which corresponds to the precise point  of when it stopped.
Thanks a lot in advance!!
  • If you have logging to file in preferences->enabled basic settings enabled you can see the last commands send.
    Be aware that the next start of the host will delete the log! So save and check before starting.
    Then you would need to find the line - best with a editor with search function. Once you know the line you can edit and hope you can home without touching the object. One reason why I prefer z max homing.
