Repetier-Host stall printing with large G-code
When printing large G-code, says 5 000 000 lines, Repetier-Host stall for many seconds when switching from Manual Control to Preview. Changing the Preview display also stall the print many seconds, creating large blobs while the nozzle doesn't move. I'm using the latest software BTW.
  • Switching between some tabs causes a recreation of the view. Especially with big prints this can keep main thread busy for too long causing a stall until finished. For this reason and some others the next release will include our Repetier-Server from next release on. If you then print over the server instead directly from the host that will not happen. You could even exit the host and restart without stopping the print.
