What switch for Z-levelling on Teensyluu board
Hi
I have no idea where to connect the Z-levelling switch on a Teensyluu board, I checked the PINS.H but could not find the right point.
Can I use the extruder endstop for this and what pin connection is that?
Any advise please? 8-|
Regards
Ed
  • There is no extruder endstop. You can use any free pin you like, all you need is to know the pin number.
    MOst use min or max endstop depending on which is not used. Not sure if teeny has both. But I guess it still has some extension pins you could use.
  • Thanks,
    I'll check it out
    Ed
