z axe move very slow
I have a prusa i3 and x and y axes work fine but z axe turn very slow... he have a power but not the speed...May you  tell me  what is the setting on the firmware for the z axe...I have an other problem, the extruder motor change direction when i aadvance manualy with the same button...
  • Z speed is limited by max z speed. Rod based z axis ARE slow compared to x and y. They can't go so fast a sthey have a higher resolution and friction is higher.
    Extruder watch out if relative or absolute mode and which coordinate you are at! Espcieally after it has been used sending G1 E1 can cause a back move when extrusion was already at E > 1.
