Load multiple STL files at once
At the moment, it is possible to put multiple objects onto the printing bed, but you have to open each file separately.
It would be more convenient to simply select a bunch of files with Ctrl and/or Shift keys to be loaded.
  • Click on the plus sign in the object placement tab and select as many stl as you want. That dialog accepts any number. The load button in toolbar is also meant for gcodes and can only handle one file for that reason.
