Support under radius
I just moved to Repetier on an XYZPrinting DaVinci 1.0.  I have printed a part successfully using the XYZ software but I'm struggling with Repetier.  I am slicing with CuraEngine and I can't get the support to fill in underneath a radius (or fillet).  As you can see in the attached image, the support fails to build under the radius.  This area is looks awful in the finished part.  Do you have any suggestions for how to get support to build in this area?
  • That looks pretty much like it is supposed to be. Small overhangs do not need support. In Structures->Support->Overhang Angle can you set the angle from where you want support. So if you want more support change that angle accordingly.
