New Image Raspian Server not visible
I'm using a new raspian image + Repetier-Server 5.1 + Raspberry Pi B.
Installation ok but can't add user to group intserial and ugpio - groups dosn't exit
server starts and is running but I can't open it @ localhost or ip. nmap scan shows only ssh as open, active port.
  • Don't bother about missing groups. This is for other linux os where it is needed, so failing in pi is ok here.
    run
    ps aux | grep tier
    to see if it is running.
    Check /var/lib/Repetier-Server/logs/server.log for some hint's on what went wrong.
    Localhost on pi will not work on the old pi, that will crash the server and pi is not fast enough to run webpage. Maybe Pi 2 can do it. So try from external device only!
    /etc/init.d/RepetierServer restart
    to start again.
