New Board
I nanoPi S2 with lcd touch 3.5 "
You can get information about how to install the server.
I see that someone has managed to run it on this platform
thanks
  • I know spaklab uses them and have compiled a kernel that works also with serial ports on nanopi. I think that was the main problem. The rest should work just as any other linux version.
  • edited October 12
    i from original installer raspian jessie loaded
    http://wiki.friendlyarm.com/wiki/images/7/71/NanoPC-S2-eMMC.png
    then server 0.86.2.armhf.
    everything works well but I can not install the touch
  • OK, connecting lcd/touchscreen is a installation problem I can not help with. Vendor should have documented how to do this and in case needed provide the right drivers.
