unable to print skirt
hey guys, thought this would be an easy question, couldn't find in search (sorry).
Using cura, i've adjusted different values (min/max  and changed distances too), still will not print.
I switched from Slcr (easy to adjust skirt).
Thanks for any help
  • edited September 29
    Are you using the curaengine in RH? The skirt settings are under the Slicer Tab - Configuration - Print Tab (on left) - Structures (with curaengine selected as the slicer). Then under the Slicer tab on the right you need to change the adhesion type when setting up print.
  • Yes. In RH, I go into Config... under "Skirt and Brim" I adjust my settings as normal. But, under "Adhesion Type" there are only three options: None, Brim, and Raft.
    Since I normally use a brim, that kinda sorta works as a skirt, but it can get messy so I really would like to solve this problem.
  • i hope that's not it, but i was able to get a skirt but only at the cost of not having a brim or raft.  that sucks.
  • As far as I know that's what you'll have to choose from, with CuraEngine in RH.
  • Thanks Roko
