Manual Z move not working at all
I home my Z axis to the max and if i hit any of the Z movement buttons it will move the axis down to the bottom. I have it calibrated right and it works with pronterface fine. The thing is it was working the day I set the machine up then stopped the next day after waking the computer up(rep host was disconnected then pc set to sleep leaving host open). I am running win 10 pro 64bit.
I have tried rebooting the machine multiple times and force closing rep host from task manager but nothing worked.
Any help is appreciated
  • using version 2.0.5
  • What is host showing as Z position after homing? I guess you have not defined z home position in printer settings so it assumes Z=0 while you are at z max.
