Printer not moving after starting a job, but gcode is running in console
Hi!
Just an amateur printer trying to hook up repetier server to free up my laptop from dedicated printing sessions.. i used repetier host in the past and also played with octoprint..
I can control my printer manually, but when I start a job the printer just sits there.  In the console if i turn on commands and ack i can see the following gcode running:
13:28:51.624: ok (2)
13:28:51.624: N1167 G1 Z30.000 F120
13:28:51.624: N1168 G92 E0.0000
13:28:51.624: N1169 G1 F120
13:28:51.632: ok (3)
Is something wrong with the communication of the server to the printer??
Thanks for any and all help in advance!
-Stephen
  • This code in the console seems to be repeating or hinting at what the communication error may be.. just cant decipher the lines myself --
    13:37:38.751: ok T:195.5 /195.0 B:50.3 /50.0 @:31 B@:18 (2)
    13:38:09.748: Warning: Communication timeout - resetting communication buffer.
    13:38:09.748: Connection status: Buffered:0, Manual Commands: 2, Job Commands: 5000
    13:38:09.748: Buffer used:0 Enforced free byte:340 lines stored:0
    13:38:09.749: M117 ETA 13:37:45 day 24
    13:38:09.751: ok
    13:38:09.759: ok T:194.8 /195.0 B:50.2 /50.0 @:43 B@:25 (2)
    13:38:40.755: Warning: Communication timeout - resetting communication buffer.
    13:38:40.755: Connection status: Buffered:0, Manual Commands: 2, Job Commands: 5000
    13:38:40.755: Buffer used:0 Enforced free byte:340 lines stored:0
    13:38:40.755: M117 ETE 00:00:00
    13:38:40.761: ok
    13:38:40.765: ok T:194.9 /195.0 B:50.4 /50.0 @:45 B@:15 (2)
  • Buffer used:0 Enforced free byte:340 lines stored:0
    that is strange - why should server need 340 byte to send a command. No firmware has such a big buffer and no gcode should need it. Only comments could be that long but do not get send. Any idea what command it want's to send here?
