Installed a long extruder, now it hangs too low on my Davinci 1.0. How do I lower the bed home?
edited August 2017 in Extruder & Bed
Here is a picture of the situation. The e3D Volcano hangs about 10mm lower than a standard e3d v6. Where can I adjust a setting to get my bed to home lower? or should I move the home switch down?
Repetier host v2.01
Firmware 0.92
http://i.imgur.com/B6WdFwG.jpg
  • If you have a Z-min home switch you will need to move it lower
    If you use a Z max home switch, you need to alter the Z max length in firmware
  • Do you mind me asking if you fixed your issue?
    If you did fix it can you tell me how you did it because I am having the same issue and I just cant seem to solve it.
