Extruder motor not responding
Thanks for watching my question,
I got a little problem with the ''Extruder Motor''
the motor just won't respond when the 3d printer is printing. (Kossel K800XL)
I checked the motor and it worked if i switched the wire with a X or Y motor so its not defect.
I think that the problem indicates to the behaviors of the temperatures.
I read that the motor won't respond if the extruder don't pass the minimum temperature.
But the temperature matches correct with the repetier host software so i don't understand why it won't respond.
Do i need to change something physical with the controller board?
or
Do i need to change something inside the configuration.h/pins.h?
thanks in advance.
Link
Controller board: http://reprap.org/wiki/Minitronics_10
_______________________________________________________________________________________________________
Configuration.h
#define NUM_EXTRUDER 1
#define MOTHERBOARD 702
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 200
#define YAXIS_STEPS_PER_MM 200
#define ZAXIS_STEPS_PER_MM 200
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define SHARED_EXTRUDER_HEATER 1
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 200
#define EXT0_TEMPSENSOR_TYPE 2
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 1
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 370
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
#define EXT1_HEATER_PIN HEATER_2_PIN
#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define EXT1_INVERSE 0
#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define EXT2_X_OFFSET 0
#define EXT2_Y_OFFSET 0
#define EXT2_Z_OFFSET 0
#define EXT2_STEPS_PER_MM 370
#define EXT2_TEMPSENSOR_TYPE 1
#define EXT2_TEMPSENSOR_PIN TEMP_3_PIN
#define EXT2_HEATER_PIN HEATER_3_PIN
#define EXT2_STEP_PIN ORIG_E2_STEP_PIN
#define EXT2_DIR_PIN ORIG_E2_DIR_PIN
#define EXT2_INVERSE 0
#define EXT2_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define EXT2_ENABLE_ON 0
#define EXT2_MIRROR_STEPPER 0
#define EXT2_STEP2_PIN ORIG_E2_STEP_PIN
#define EXT2_DIR2_PIN ORIG_E2_DIR_PIN
#define EXT2_INVERSE2 0
#define EXT2_ENABLE2_PIN ORIG_E2_ENABLE_PIN
#define EXT2_MAX_FEEDRATE 50
#define EXT2_MAX_START_FEEDRATE 20
#define EXT2_MAX_ACCELERATION 5000
#define EXT2_HEAT_MANAGER 3
#define EXT2_WATCHPERIOD 1
#define EXT2_PID_INTEGRAL_DRIVE_MAX 230
#define EXT2_PID_INTEGRAL_DRIVE_MIN 40
#define EXT2_PID_PGAIN_OR_DEAD_TIME 7
#define EXT2_PID_I 2
#define EXT2_PID_D 40
#define EXT2_PID_MAX 255
#define EXT2_ADVANCE_K 0
#define EXT2_ADVANCE_L 0
#define EXT2_ADVANCE_BACKLASH_STEPS 0
#define EXT2_WAIT_RETRACT_TEMP 150
#define EXT2_WAIT_RETRACT_UNITS 0
#define EXT2_SELECT_COMMANDS ""
#define EXT2_DESELECT_COMMANDS ""
#define EXT2_EXTRUDER_COOLER_PIN -1
#define EXT2_EXTRUDER_COOLER_SPEED 255
#define EXT2_DECOUPLE_TEST_PERIOD 12000
#define EXT2_JAM_PIN -1
#define EXT2_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_PID_IGAIN   33
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 285
#define MAX_DEFECT_TEMPERATURE 300
______________________________________________________________________________________________________________________________________________________________________________________________________________
Pins.h
* Minitronics v1.0
#if MOTHERBOARD == 702
#define KNOWN_BOARD 1
#ifndef __AVR_ATmega1281__
#error Oops! Make sure you have 'Minitronics ' selected from the 'Tools -> Boards' menu.
#endif
#define LARGE_FLASH true
#define ORIG_X_STEP_PIN 48
#define ORIG_X_DIR_PIN 47
#define ORIG_X_ENABLE_PIN 49
#define ORIG_X_MIN_PIN -1
#define ORIG_X_MAX_PIN 5
#define ORIG_Y_STEP_PIN 39
#define ORIG_Y_DIR_PIN 40
#define ORIG_Y_ENABLE_PIN 38
#define ORIG_Y_MIN_PIN -1
#define ORIG_Y_MAX_PIN 2
#define ORIG_Z_STEP_PIN 45
#define ORIG_Z_DIR_PIN 44
#define ORIG_Z_ENABLE_PIN 27
#define ORIG_Z_MIN_PIN 25
#define ORIG_Z_MAX_PIN 6
#define ORIG_E0_STEP_PIN 42
#define ORIG_E0_DIR_PIN 43
#define ORIG_E0_ENABLE_PIN 38
#define ORIG_E1_STEP_PIN 36
#define ORIG_E1_DIR_PIN 35
#define ORIG_E1_ENABLE_PIN 37
#define ORIG_E2_STEP_PIN -1
#define ORIG_E2_DIR_PIN -1
#define ORIG_E2_ENABLE_PIN -1
#define SDPOWER -1
#define SDSS 16
#define SCK_PIN 10
#define MISO_PIN 12
#define MOSI_PIN 11
#define LED_PIN 46
#define ORIG_FAN_PIN 9
#define ORIG_FAN2_PIN -1
#define ORIG_PS_ON_PIN -1
#define KILL_PIN -1
// EXTRUDER 1
#define HEATER_0_PIN 7
// BED
#define HEATER_1_PIN 3
// EXTRUDER 2
#define HEATER_2_PIN 7
#define HEATER_3_PIN -1
// ANALOG NUMBERING
#define TEMP_0_PIN 7
// BED SENSOR ANALOG NUMBERING
#define TEMP_1_PIN 6
// ANALOG NUMBERING
#define TEMP_2_PIN 6
// ANALOG NUMBERING
#define TEMP_3_PIN -1
#define BEEPER_PIN -1
  • 1st,  make sure 'dry run' is not selected in repetier host manual tab.
  • edited August 2017
    dear MartinH
    Thanks for your reaction
    The dry run mode is not selected in the repetier host manual,
    i am almost sure that it has something to do something with the extruder temperatures
  • M302 S0    this will allow cold extrusion to test if it is a temp sense problem.
    Does the extruder get hot enough to melt filament ?
    Is the extruder motor turning the correct direction ? (sounds silly but i have been fooled by this myself).
  • I think I had a wrong description for that.
    M302 S<0 or 1> - allow cold extrusion. Without S parameter it will allow. S1 will allow, S0 will disallow.
    so M302 S1 shoudl allow cold extrusion. Thanks for pointing me to this.
  • Ahh ty for clearing that up, on the reprap g code wiki  it states that M302 will just report cold extrusion state
  • Thanks for the advice
    But even with the cold extrusion the motor ''still won't respond.''
    so i am thinking right now that it mabye got something to do with a physical connection.
    but everythings seems to be okey at the controller board
  • To test that you could swap X axis and E axis driver, so X uses E driver. In config tool this is easy to define. Then you see if the driver works as x axis. If not it is likely that something electronic wise is bad. You could also try second extruder driver instead.
  • I switched the extruder with the ''X axis'' and its working fine.
    The repetier host software says ''SelectExtruder0''
    i see in the EEPROM settings only a ''EXTR. 1'' option.
    I think that the repetier host software or firmware selected a different extuder channel
    (so extruder 0 instead of extruder 1) because the motor also didin't respond to ''cold extrusion''
  • Firmware counts extruders from 0 while hosts count from 1. SelectExruder0 means extruder 1 in host.
