Adjusting Travel Move Path
Is there a way in the Cura Engine to adjust the travel moves so they arn't over open spaces.
I am printing something that had a solid back but detailed front and the travel moves are over the detail when they could be over the back and not cause oozing over the front.
So apart from manually doing each one, can i get cura to do it automatically?. If not should i use another slicer?
Thanks,
  • There should be a option avoid crossing perimeter or similar that reduces this to a minimum.
