RAMPS, Chimera and RRD Fan Extender
Hi
 I am quite new to the Repetier firmware, but found out, that this probably was the way to go, if I wanted to convert my RAMPS 1.4 based printer to use the Chimera extruder  together with the RRD Fan Extender.
I wonder if anyone has done a similar setup - where I can get the config file(s) for inspiration?
As far as I can see, Print Cooling Fan and Print Second Fan pin need to be set for D11 and D6.
But I am a bit in doubt regarding the pins for the heated bed and the two extruders...
Can anyone give me some qualified input ;-)
Regards
Brian
