slicer extrusion g code
Using repetier with slicer need to express some filament before start of print as it dry prints with no filment flow and misses half a layer of extrusion
Tried
M104 S180 T0
G28 ; home all axes
G1 Z 10
G91
G1 E10 F240
G1 90
G28 Z
G1 Z5 F5000 ; lift nozzle
No improvement
any suggestions?
  • No space after letters, no double home z, g1 90 is no valid command. After going to z10 add
    M109 S180
    to wait for extruder to reach 180.
  • thanks
    Will try this below
    Note  went to 195 as pla temps charts say 190-210 maybe 180 was too low to flow
    M104 S195 T0
    G28 ; home all axes
    G1 Z10
    M109 S195
    G91
    G1 E10 F240
    will try this when i return
    having some better printing with my tests this one the pla (test boat Thingiverse) was about 210 too hot i suspect some stringing still not  bad for a large format test this is about 1" overall  Was kind of a slow print once i can do repeatably will speed up the print time right now it is at the standard defaults.
  • edited August 10
    You should also zero the extrude before and after extruding.
    G90
    G92 E0
    G1 E10 F240
    G92 E0
    You can use placeholder with slic3r to use the temp settings in slic3r config.
    http://mauk.cc/mediawiki/index.php/Slic3r_placeholders
  • M104 S195 T0
    G28 ; home all axes
    G1 Z10
    M109 S195
    G91
    G90
    G92 E0
    G1 E10 F240
    G92 E0
    Seems to make sense (this is all in the start script section of the Slicer)
    anything else?
  • G91  relative move is not needed
  • ran into a minor issue:
    when the express is completing the nozzle comes down into the express puddle and drags the expressed across the bed. move to start position before lowering?
    The 2nd issue the Extruder cooling fan is not coming on (have to do so manually)
    No filament fan, and no bed heater either
    Will remove the G91 as noted
    thanks in advance
  • Move sideways after extrusion
    G1 X20 F6000
    then it. Goes down there.
    The rest is wrong configuration i guess. Make sure to not use pins double for fans and heaters and to set right pin. Numbers.
  • turns out the fan is working, turns on at some point. will add G1 X20 F6000 after extrusion.
    thanks
  • thanks everyone got that working as suggested :>)
