Eleduino 7-inch usb touch display compatibility
Hi guys
I'm currently looking to purchase Repetier-Server and run it on the Pi 2 (since I currently run the free version for Windows with much success)
I'd like to know if this display is supported by your current build of Repetier-Server?
Eleduino Raspberry Pi 7 Inch 1024x600
If not, would I be able to run Raspbian (which does support the display+touch through USB) and install repetier server as a deb package for arm?
Best,
Seven
  • Since they state "The touchscreen can support Pi 3 Now !only just edit config.txt for setting resolution or use we provide config at our website,make sure the the power supply is 5V 2.5A for Pi or extal power for touchscreen" it should work with just the modification they mention.
    The image is just the stock raspbian stripped down and preconfigured. But depending on display/touchscreen you might need to add the drivers/settings the screen vendor offers to see it.
  • edited July 2017
    Thank you! I've just purchased the pro version of Repetier Server. I hope to build this touch screen setup for a standalone print server.
    I'll let you know if it works!
