Delta Homing Issue
Hello
I switched from Marlin to Repetier 0.91 on my Delta. Everything works so far except homing. When I send G28 all three axis move up but then stop after about 10mm without triggering the endstops. It reads then the coordinates of the homed position and I can drive the axis normally. Did anyone else had a similar problem?
Thank you for your Help
Here is my configuration.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   This file is optimized for version 0.91
   as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 80
#include "pins.h"
#define FAN_BOARD_PIN -1
//#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
// Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
// If it is incompatible you will get compiler errors about write functions not beeing compatible!
//#define COMPAT_PRE1
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 80
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_STEPS_PER_MM 206
#define EXT0_INVERSE 0
#define EXT0_ENABLE_PIN E0_ENABLE_PIN
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 70
#define EXT0_MAX_START_FEEDRATE 55
#define EXT0_MAX_ACCELERATION 10000
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_P 7
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define HEATED_BED_MAX_TEMP 90
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_HEAT_MANAGER 2
#define HEATED_BED_PID_PGAIN   196
#define HEATED_BED_PID_IGAIN   33
#define MIN_EXTRUDER_TEMP 170
#define MAXTEMP 275
#define ENDSTOP_X_BACK_MOVE 3
#define ENDSTOP_Y_BACK_MOVE 3
#define ENDSTOP_Z_BACK_MOVE 3
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 1
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 479
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
// ##                           Movement settings                                          ##
// Delta settings
#define DELTA_DIAGONAL_ROD 300 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 130
#define DELTA_RADIUS 163.8
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
//#define SOFTWARE_LEVELING
#define MAX_DELTA_SEGMENTS_PER_LINE 24
#define STEPPER_INACTIVE_TIME 180L
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 500
#define MAX_FEEDRATE_Y 500
#define MAX_FEEDRATE_Z 500
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 40
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define STEP_DOUBLER_FREQUENCY 10000
#define ALLOW_QUADSTEPPING 1
#define MAX_HALFSTEP_INTERVAL 1999
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 3000
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_SIZE 16
#define MOVE_CACHE_LOW 10
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define X2_ENABLE_PIN E1_ENABLE_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_ENABLE_PIN E1_ENABLE_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_ENABLE_PIN E1_ENABLE_PIN
#define BAUDRATE 250000
#define ENABLE_POWER_ON_STARTUP
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define GCODE_BUFFER_SIZE 2
#define ACK_WITH_LINENUMBER
#define ECHO_ON_EXECUTE
#define EEPROM_MODE 1
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define FEATURE_WATCHDOG 0
#define FEATURE_Z_PROBE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
#define SDSUPPORT 0
#define SDCARDDETECT -1
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 0
#define UI_LANGUAGE 0
#define UI_ANIMATION 1
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
#define UI_SET_MIN_HEATED_BED_TEMP  30
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
  • First I would upgrade to newer repetier version. Why start with ancient version:-)
    Check endstops with M119 if signals get send correctly. If it stops early you have either set z length so small or have crosstalk to endstops if they work otherwise. Please check eeprom settings - a typical problem when users come from Marlin. We have stored most data on first upload in eeprom and later changes in configration.h are not copied automatically.
    M502
    M500
    would copy values to eeprom.
  • Thank you for the fast reply :)
    I had some communication problem with 0.92. I am not sure if it's a matter of the firmware but I want to try the 0.91 first before I change hardware. As I said, I printed with Marlin before and hadn't any problems. But repetier is much smoother. That's why I want to give it a try.
    I already checked the endstops with M119 and they work fine. My Z length should be enough. I will try to copy the values to eeprom and hopefully it will change something.
  • One more thing. On deltas make sure to always have at least 900 byte free ram when arduino reports it. For deltas we use all available ram to increase subsegments for moves so this can easily use up all ram and then strange things happen.
  • This could be the problem that caused the strange behavior with 0.92. I will try to change that.
    Thank you
