temp fail
I am using the host on windows and I get all heated up, then I start to print. it auto turns off my heaters, and when I turn back on, the temp plummets. Also the freezing part is when I switch between and at random
  • > Also the freezing part is when I switch between and at random
    Switch between what?
    What firmware?
    What are the log contents when that happens?
  • I don't know about the last sentence, and I have  http://www.solidoodle.com/parts/parts-SD4/parts-SD4-motherboard. The logs are M104 S0 ; turn off temperature
    G28 X0  ; home X axis
    M84     ; disable motors
    ; filament used = 3643.2mm (25.8cm3)
    ; avoid_crossing_perimeters = 0
    ; bed_size = 200,200
    ; bed_temperature = 0
    ; bridge_acceleration = 0
    ; bridge_fan_speed = 100
    ; bridge_flow_ratio = 1
    ; brim_width = 0
    ; complete_objects = 0
    ; cooling = 1
    ; default_acceleration = 0
    ; disable_fan_first_layers = 1
    ; duplicate_distance = 6
    ; external_perimeters_first = 0
    ; extruder_clearance_height = 20
    ; extruder_clearance_radius = 20
    ; extruder_offset = 0x0
    ; extrusion_axis = E
    ; extrusion_multiplier = 1
    ; fan_always_on = 0
    ; fan_below_layer_time = 60
    ; filament_diameter = 3
    ; first_layer_acceleration = 0
    ; first_layer_bed_temperature = 0
    ; first_layer_extrusion_width = 200%
    ; first_layer_speed = 30%
    ; first_layer_temperature = 190
    ; g0 = 0
    ; gcode_arcs = 0
    ; gcode_comments = 0
    ; gcode_flavor = reprap
    ; infill_acceleration = 0
    ; infill_first = 0
    ; layer_gcode =
    ; max_fan_speed = 100
    ; min_fan_speed = 35
    ; min_print_speed = 10
    ; min_skirt_length = 0
    ; notes =
    ; nozzle_diameter = 0.5
    ; only_retract_when_crossing_perimeters = 1
    ; ooze_prevention = 0
    ; output_filename_format = [input_filename_base].gcode
    ; perimeter_acceleration = 0
    ; post_process =
    ; print_center = 117,100
    ; resolution = 0
    ; retract_before_travel = 2
    ; retract_layer_change = 1
    ; retract_length = 1
    ; retract_length_toolchange = 10
    ; retract_lift = 0
    ; retract_restart_extra = 0
    ; retract_restart_extra_toolchange = 0
    ; retract_speed = 30
    ; skirt_distance = 6
    ; skirt_height = 1
    ; skirts = 1
    ; slowdown_below_layer_time = 30
    ; spiral_vase = 0
    ; standby_temperature_delta = -5
    ; start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n
    ; temperature = 190
    ; threads = 2
    ; toolchange_gcode =
    ; travel_speed = 130
    ; use_firmware_retraction = 0
    ; use_relative_e_distances = 0
    ; vibration_limit = 0
    ; wipe = 0
    ; z_offset = 0
    ; dont_support_bridges = 1
    ; extrusion_width = 0
    ; first_layer_height = 0.35
    ; infill_only_where_needed = 0
    ; interface_shells = 0
    ; layer_height = 0.4
    ; raft_layers = 0
    ; seam_position = aligned
    ; support_material = 0
    ; support_material_angle = 0
    ; support_material_enforce_layers = 0
    ; support_material_extruder = 1
    ; support_material_extrusion_width = 0
    ; support_material_interface_extruder = 1
    ; support_material_interface_layers = 3
    ; support_material_interface_spacing = 0
    ; support_material_interface_speed = 100%
    ; support_material_pattern = pillars
    ; support_material_spacing = 2.5
    ; support_material_speed = 60
    ; support_material_threshold = 0
    ; bottom_solid_layers = 3
    ; bridge_speed = 60
    ; external_perimeter_speed = 70%
    ; extra_perimeters = 1
    ; fill_angle = 45
    ; fill_density = 40%
    ; fill_pattern = honeycomb
    ; gap_fill_speed = 20
    ; infill_every_layers = 1
    ; infill_extruder = 1
    ; infill_extrusion_width = 0
    ; infill_speed = 60
    ; overhangs = 1
    ; perimeter_extruder = 1
    ; perimeter_extrusion_width = 0
    ; perimeter_speed = 30
    ; perimeters = 3
    ; small_perimeter_speed = 30
    ; solid_fill_pattern = rectilinear
    ; solid_infill_below_area = 70
    ; solid_infill_every_layers = 0
    ; solid_infill_extrusion_width = 0
    ; solid_infill_speed = 60
    ; thin_walls = 1
    ; top_infill_extrusion_width = 0
    ; top_solid_infill_speed = 50
    ; top_solid_layers = 3
    and at the top
