external access through SSL
For external access I configured a port forwarding in my router to be able to enable SSL access from WAN. So the server can be accessed through the https protocol. In the configuration page I entered the full web address, including https://. Now the QR-code translate to http://https://web.server.org. How can that the server adds the 'http://' ?
Mike
  • Hi,
    Mike
  • You can't. As you see th efield is only the domain name and the server adds http:// on it's own. Will check if I can use that to override in a future version. Except the qr code it does not affect anything else, so you still can use it if nginx does the proxy work to non ssl.
