update of prusa edition
Hi
Is there a guide to how i can update the build in prusa edition of slic3r? just so i can keep up to date. Latest version is 1.35.5
  • edited June 18
    i tried to unzip the latest version in a new folder under repetier host folder and point to that from within repetier host
    but i get this long error list: https://pastebin.com/PC1CWihY
    and slic3r does not open
  • also when i open this manual (ie not through repetier host) its a lot unresponsive to the point where its useless
    is that why it has not been updated yet?
    i tried to use the latest settings from prusa but these give me this much shorter error list:
    https://pastebin.com/4ptfHGCv
  • They update quite often so we can not follow every update. When we update we will include the latest version of course.
    The trick is to point to the console version and not the gui version and select the "Slic3r Prusa Edition" slicer to it not the "Slic3r" version, since prusa needs different handling.
  • ahh.... that makes sense, i pointed to the gui version.. will fix that
    i tried to enable variable layer height and i got this error:
    15:25:58.109 : <Slic3r> Caught C++ exception of type or derived from 'std::exception': vector<T> too long at C:/PROGRA~1/REPETI~1/Slic3rPE/lib/Slic3r/Print/Object.pm line 197.
    15:25:58.242 : <Slic3r> Slic3r installed in a loclized path. Using an 8.3 path: "C:\PROGRA~1\REPETI~1\Slic3rPE\"
    any clue that what that could be?
  • btw i uninstalled the normal slic3r version so its not messing things up
    i extracted the latest from prusa in a new folder and pointed to: C:\Program Files\Repetier-Host\Slic3r_New\slic3r-console.exe
    still it will not run, will try and see if i did anything wrong
    when i launch the gui version directly i can get it to run with all settings etc availble, but its just so slow :-D
  • i have given up on updating to the latest version
    but i would still like to use variable height
  • With bundeled version it worked great. Soon I update host and will include new slic3r PE so then I will see if they have changed something making it incompatible. After all it is a quite new feature so changes may happen.
  • i do use the bundeled version :-D
    updating was to much trouble for me
  • aah, I see what the problem is, "--gui-mode simple/expert" has been removed.
    This is according to the changelog on the web site.
    The following features were removed:
       The "simple" mode has been removed as it was too simplistic, therefore nobody used it.
    The "--gui" option is still there, but if you call it with "--gui-mode <simple/expert>" it just gives the calling instructions.
    I would suggest you remove the "--gui-mode" part or tell us where you add the "--gui-mode" part and we can remove it ourselves?
  • It is inside the dll compiled in, so nothing you can change. But since we include that version in near future I will fix that switch for upcoming versions. Thats the classic problem if commandlines change.
  • I know you probably get asked this often, but when do you expect to have a new version, with this change available?
  • In july we plan an update.
