Rotate Raspberry Pi screen image
I am using the server software on a raspberry pi 3 touch screen. It works great, however the screen is upside down. Can I rotate it anywhere in the settings? I can remount the screen, but don't really want to do that. Is it somewhere in the terminal application I can do this?
Thanks very much.
  • From image documentation:
    Rotate Display
    Depending on how you have mounted the display, you may need to rotate the screen. To do this, login and run
    sudo nano /boot/config.txt
    and search for a line
    # Rotate screen 180°
    lcd_rotate=2
    A value of 0 is no rotation, 2 = 180°.
