Printing from SD card and server commands
Hello Repetier,
While printing from an SD card, will server commands such as "@pause" be execute by Repetier-Server?
For example, if @pause is placed in a specific location in the gcode file on SD card, will Repetier-Server tell the printer to pause when running in to the command?
- Nate
  • No they won't. Printing from sd card bypasses the server completely. That is why we do not support sd printing server side at all. You loose all advantages of the server.
