Adding rotary encoder with I2C OLED display
I've been tinkering with the firmware and now have an OLED display working via I2C.  B)
Now I'd like to add a way to use the menus. Hopefully with a rotary encoder. I can connect this in the same pinout as used for the "Smart" controllers. What changes in the firmware configuration do I need to make for the encoder to work?
  • Check it in ui.h or displaylist.h for 1.0 version. Each controller has a section setting pin numbers and at the end 2 functions handling the keys.
  • edited June 13
    Thank you Repetier. I'm not too much of a coder and am finding myself confused as to where I may either enable or define the encoder. 1.1 dev is what I think I've downloaded.
    I read both the ui.h and displaylist.h files and see no obvious place for this.
    RAMPS 1.4 board, The encoder is connected as follows:
    Button A 33
    Button B 35
    Click button 37
    Thanks again.
  • how did you set up yor display?
    did you use the uiconfig.h?
  • Yes uiconfig.h
    #define UI_DISPLAY_TYPE 5
    #define U8GLIB_SSD1306_I2C
  • edited June 14
    so it´s simple to add Encoder.
    in configuration.h
    set #define FEATURE_UI_KEYS 1
    in uiconfig.h
    uncomment   //  UI_KEYS_INIT_CLICKENCODER_LOW(33,31);  and replace the pin numbers by yours
    do the same for //UI_KEYS_CLICKENCODER_LOW_REV(33,31)
    similar  for button , assign pin number/function
    so at least the part in your uiconfig.h should be
    void uiInitKeys() {
    #if UI_HAS_KEYS!=0
      UI_KEYS_INIT_CLICKENCODER_LOW(33,35);
      UI_KEYS_INIT_BUTTON_LOW(37); // push button, connects gnd to pin
    #endif
    void uiCheckKeys(uint16_t &action) {
    #if UI_HAS_KEYS!=0
     UI_KEYS_CLICKENCODER_LOW_REV(33,35);
     UI_KEYS_BUTTON_LOW(37,UI_ACTION_OK); // push button, connects gnd to pin
    #endif
    think that should work for you, if Encoder direction is wrong, just swap the pin numbers
  • Thank you RAyWB. I'll hack on that when I get home from work.
  • edited June 14
    This works. Thank you so very much.
    (Note to self -- This works better if you actually connect to pins 33, 35, and 37. Not 31, 33, 35.... :blush: )
