Warning: Communication timeout - resetting communication buffer.
Problems occur during heating when first printing is applied. But if the printing is canceled and reprinted, the error occurs during heating. If the Repetier server is deactivated and restarted, the first print does not generate an error. But there is an error during heating other printing.
 Not Error first printing;
8:17:52.128: N47 M109 S200.000000
8:17:52.152: X:100.00 Y:0.00 Z:133.00 E:0.00 Count X: 10000 Y:0 Z:27400
8:17:52.152: ok
8:17:52.152: N48 G21 ;metric values
8:17:52.153: N49 G90 ;absolute positioning
8:17:52.154: ok
8:17:52.154: echo: cold extrusion prevented
8:17:52.155: N50 M82 ;set extruder to absolute mode
8:17:52.157: echo: cold extrusion prevented
8:17:52.164: ok (3)
8:17:52.164: T:48.8 /200.0 @:0 W:?
8:17:52.164: N51 M107 ;start with the fan off
8:17:52.165: N52 G28 X0 Y0 ;move X/Y to min endstops
8:17:52.165: N53 G28 Z0 ;move Z to max endstops
8:17:54.161: T:48.7 /200.0 @:127 W:? (2)
8:17:55.162: T:48.8 /200.0 @:127 W:?
8:17:56.162: T:49.3 /200.0 @:127 W:?
8:17:57.163: T:50.2 /200.0 @:127 W:?
8:17:58.161: T:51.1 /200.0 @:127 W:?
8:17:59.163: T:52.4 /200.0 @:127 W:?
8:18:00.162: T:53.9 /200.0 @:127 W:?
Error other printing:
8:17:57.361: X:3.00 Y:0.00 Z:0.00 E:0.00 Count X: 300 Y:0 Z:0
8:17:57.361: ok
8:17:58.245: X:3.00 Y:98.00 Z:133.00 E:0.00 Count X: 300 Y:9800 Z:27400
8:17:58.245: ok
8:17:58.245: N47 M105
8:17:58.246: N48 M105
8:17:58.347: X:3.00 Y:98.00 Z:133.00 E:0.00 Count X: 300 Y:9800 Z:27400
8:17:58.350: ok (2)
8:17:58.351: echo: cold extrusion prevented
8:17:58.351: N49 M109 S200.000000
8:17:58.351: N50 G21 ;metric values
8:17:58.353: echo: cold extrusion prevented
8:17:58.357: ok (3)
8:17:58.358: ok T:117.9 /0.0 @:0
8:17:58.358: N51 G90 ;absolute positioning
8:17:58.358: N52 M82 ;set extruder to absolute mode
8:17:58.358: N53 M107 ;start with the fan off
8:17:58.358: N54 G28 X0 Y0 ;move X/Y to min endstops
8:17:58.359: N55 G28 Z0 ;move Z to max endstops
8:17:58.360: ok T:117.9 /0.0 @:0
8:17:58.362: T:117.9 /200.0 @:0 W:?
8:17:59.361: T:117.6 /200.0 @:127 W:?
8:18:00.361: T:117.3 /200.0 @:127 W:?
8:18:01.362: T:117.1 /200.0 @:127 W:?
8:18:02.360: Warning: Communication timeout - resetting communication buffer.
8:18:02.361: Connection status: Buffered:114, Manual Commands: 2, Job Commands: 5000
8:18:02.361: Buffer used:114 Enforced free byte:23 lines stored:8
8:18:02.361: M117 ETA 08:31:22 day 6
8:18:02.361: T:117.2 /200.0 @:127 W:?
8:18:02.362: N56 M105
8:18:02.362: N57 M105
8:18:02.362: N58 G1 Z115.0 F3600 ;move th e platform up 20mm
8:18:02.362: N59 G28 Z0 ;move Z to max endstop
8:18:02.362: N60 G1 Z15.0 F3600 ;move the platform down 15mm
8:18:02.363: N61 G92 E0 ;zero the extruded length
8:18:03.362: T:117.6 /200.0 @:127 W:?
8:18:04.363: T:118.3 /200.0 @:127 W:?
8:18:05.361: T:119.1 /200.0 @:127 W:?
8:18:06.363: T:120.2 /200.0 @:127 W:?
8:18:06.363: Warning: Communication timeout - resetting communication buffer.
8:18:06.363: Connection status: Buffered:123, Manual Commands: 1, Job Commands: 5000
8:18:06.364: Buffer used:123 Enforced free byte:18 lines stored:7
  • The problem here is caused by
    which is a slow command taking longer then timeout seconds. Server knows this and as long as it thinks it is not finished will not cause the timeout. It is not that visible now if the M109 got a matching ok and 5 more commands so run out of the test scope for slow commands, but somehow this is exactly what has happened.
    What firmware exactly are you using? I have seen that marlin was working on a system of extra buffer so that is what could cause the "ok" to confuse server.
    On the other side if you use such a new marlin version, it also has nice additions that help hosts to fix/detect problems much better and would have prevented this:
    - Enable busy protocol or however they call it. This tells server when firmware is running a slow command so you can even reduce timeout to 3 seconds.
    - Enable line numbers in ok. This allows detecting missed "ok" on the fly without needing to hit timeout. Also keeps performance up to a good level.
    - Enable sending "wait" when idle. This informs server that all commands are processed.
    I have no idea why they do not enable these by default. These are very big adds to stable communication.
  • edited June 12
    I am using Marlin Firmware.
    I enabled sending "wait" when idle. I configured communication timeout seconds: 3 second.
    There is an error during heating. When printing started , it resended:
    7:29:47.456: X:3.00 Y:98.00 Z:133.00 E:0.00 Count X: 300 Y:9800 Z:27400 (3)
    7:29:47.456: ok
    7:29:47.456: N1860 M105
    7:29:47.458: ok T:201.5 /200.0 @:29
    7:29:47.462: Error:checksum mismatch, Last Line: 1773
    7:29:47.466: Resend: 1774
    7:29:47.477: ok
    7:29:47.478: ok T:201.5 /200.0 @:29
    7:29:47.478: ok
    7:29:47.478: Resend: N1774 G1 Z15.0 F3600 ;move the platform down 15mm
    7:29:47.478: Resend: N1775 G92 E0 ;zero the extruded length
    7:29:47.479: Resend: M117 ETA 07:35:28 day 12
    7:29:47.479: Resend: N1776 M105
    7:29:47.479: Resend: N1777 M105
    7:29:47.479: Resend: N1778 G1 F200 E3 ;extrude 3mm of feed stock
    7:29:51.470: echo:busy: processing (2)
    7:29:52.098: X:3.00 Y:98.00 Z:133.00 E:0.00 Count X: 300 Y:9800 Z:27400 (3)
    7:29:52.098: ok
    7:29:52.098: Resend: N1779 G92 E0 ;zero the extruded length again
    7:29:52.098: Resend: N1780 G1 F3600
    7:29:52.103: ok (3)
    7:29:52.103: ok T:200.3 /200.0 @:49
    7:29:52.104: Resend: N1781 M105
    7:29:52.104: Resend: N1782 M105
    7:29:52.104: Resend: N1783 M301 H1 P26.38 I2.57 D67.78
    7:29:52.107: ok T:200.3 /200.0 @:49
    7:29:52.107: Resend: M117 Printing...
    when printing there isn't error.
  • You need to show a log where the error starts to say what goes wrong. Here you are already 100 lines after the initial error. (N1860 M105 is alread send while 1773 is last processed line according to firmware)
    What I see is you also enabled busy whcih is good. Just line numbers are still missing as last correction help.
