Two feeders one Hotend
Two feeders one Hotend - Is there a solution for this? Even if i add two feeders and pin the temp sensor together in firmware Ext0 Pin1 Ext1 Pin1 both temps on screen have to be set together and always match any temp changes to prevent failure.
  • This is for Y feeders with tool change script. Single hotend, No offsets :-)
  • Solution is to select "Extruders share same heater from extruder 0 definition (SHARED_EXTRUDER_HEATER)" in config tool. Then extruder 0 defines temperature for both.
