Failed to upload to Arduino
About 2 years ago using 0.91 i had the same sort of problem. I run through the firmware config tool, generate the ino files to upload and i get a plethora of missing declarations, i cant seem to get anything onto the board. Ive tried using arduino versions 1.8.2, 1.0.5 and 1.5.8. None of these work, each version throws up its own errors.
Following the instructions for uploading, I downloaded the latest version 1.8.2, chose my board and port but arduino fails to compile, saying theres a multitude of things undeclared. Can anyone lead me in the right direction?
Error message is as follows:
Arduino: 1.8.2 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries J:\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10802 -build-path C:\Users\XXX\AppData\Local\Temp\arduino_build_738193 -warnings=none -build-cache C:\Users\XXX\AppData\Local\Temp\arduino_cache_557936 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\Repetier\Repetier.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries J:\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10802 -build-path C:\Users\XXX\AppData\Local\Temp\arduino_build_738193 -warnings=none -build-cache C:\Users\XXX\AppData\Local\Temp\arduino_cache_557936 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\Repetier\Repetier.ino
Using board 'mega' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Repetier.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Repetier.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\BedLeveling.cpp
Using cached library dependencies for file: C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Commands.cpp
Using cached library dependencies for file: C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Communication.cpp
Using cached library dependencies for file: C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Drivers.cpp
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Eeprom.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Extruder.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\HAL.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Printer.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\SDCard.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\SdFat.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\gcode.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\motion.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\ui.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\uilang.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Repetier.ino.cpp" -o "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
Using previously compiled file: C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\BedLeveling.cpp.o
Using previously compiled file: C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Commands.cpp.o
Using previously compiled file: C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Communication.cpp.o
Using previously compiled file: C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Drivers.cpp.o
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Eeprom.cpp" -o "C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Eeprom.cpp.o"
C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Eeprom.cpp: In static member function 'static void EEPROM::restoreEEPROMSettingsFromConfiguration()':
Eeprom.cpp:99: error: 'HEATED_BED_PREHEAT_TEMP' was not declared in this scope
     heatedBedController.preheatTemperature = HEATED_BED_PREHEAT_TEMP;
Eeprom.cpp:135: error: 'EXT0_PREHEAT_TEMP' was not declared in this scope
     e->tempControl.preheatTemperature = EXT0_PREHEAT_TEMP;
Eeprom.cpp:166: error: 'EXT1_PREHEAT_TEMP' was not declared in this scope
     e->tempControl.preheatTemperature = EXT1_PREHEAT_TEMP;
C:\Users\XXX\AppData\Local\Temp\arduino_build_738193\sketch\Eeprom.cpp: In static member function 'static void EEPROM::readDataFromEEPROM(bool)':
Eeprom.cpp:772: error: 'HEATED_BED_PREHEAT_TEMP' was not declared in this scope
Eeprom.cpp:775: error: 'EXT0_PREHEAT_TEMP' was not declared in this scope
             extruder[0].tempControl.preheatTemperature = EXT0_PREHEAT_TEMP;
Eeprom.cpp:778: error: 'EXT1_PREHEAT_TEMP' was not declared in this scope
             extruder[1].tempControl.preheatTemperature = EXT1_PREHEAT_TEMP;
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
  • Error message state clearly that some defines are not there. It is important to compile with matching version. Best is download zip in config tool so you have the matching code for the configuration you got.
