After 2 Upgrade - Jobs terminate on Micromake D1
edited May 3 in Bug Reports
Print jobs terminate immediately or after one minute. Only since the update.
  • What does the log say about termination? Prints only terminate if there are communication problems or firmware reports a problem.
  • edited May 4
    With ping pong communicaton to printer ok.
    In the old version it was not necessary.
    Have you changed a default value?
    16:42:57.456 : Drucke Layer 1 von 127
    16:42:57.457 : N98 G1 X-14.699 Y-5.801 E0.69285 F900*51
    16:43:31.485 : Echo:N90 M190  S60
    16:43:31.487 : Echo:N91 M104 T0  S200
    16:43:31.488 : Echo:N92 G92  E0.0000
    16:43:31.489 : N100 M117 ETE 5h 49m 06s*57
    16:43:31.490 : Echo:N93 M109 T0  S200
    16:43:31.491 : Echo:N94 M107
    16:43:31.492 : N101 G1 X-16.491 Y-5.801 E0.79987*93
    16:43:31.492 : N102 G1 X-16.927 Y-9.126 E1.00013*85
    16:43:31.508 : Echo:N95 G0  X-14.70 Y5.80 Z0.30 F4800.00
    16:43:31.515 : N103 G1 X-17.555 Y-10.642 E1.09813*96
    16:43:31.526 : Echo:N97 M117 ETE 5h 49m 07s
    16:43:31.527 : N104 G1 X-18.553 Y-11.942 E1.196*109
    16:43:31.648 : Echo:N98 G1  X-14.70 Y-5.80 E0.6928 F900.00
    16:43:31.670 : Error:Tu:
    16:43:31.670 : Resend:100
    16:43:31.677 : Resend: N100 M117 ETE 5h 49m 06s*57
    16:43:31.677 : Resend: N101 G1 X-16.491 Y-5.801 E0.79987*93
    16:43:31.677 : Resend: N102 G1 X-16.927 Y-9.126 E1.00013*85
    16:43:31.677 : Resend: N103 G1 X-17.555 Y-10.642 E1.09813*96
    16:43:31.677 : Resend: N104 G1 X-18.553 Y-11.942 E1.196*109
    16:43:31.681 : Error:Tu:
    16:43:31.681 : Resend:100
    16:43:34.692 : Warning: Seems like we missed a ok, got a wait - continue sending.
    16:43:34.692 : N105 M117 ETE 5h 49m 05s*63
    16:43:34.692 : N107 G1 X-19.858 Y-12.944 E1.29426*105
    16:43:34.692 : N108 G1 X-21.375 Y-13.573 E1.39233*99
    16:43:34.692 : N109 G1 X-23 Y-13.787 E1.49021*112
    16:43:34.693 : N110 G1 X-24.624 Y-13.573 E1.58803*96
    16:43:34.697 : Error:Tu:
    16:43:34.697 : Resend:100
    16:43:34.704 : Resend: N100 M117 ETE 5h 49m 06s*57
    16:43:34.704 : Resend: N101 G1 X-16.491 Y-5.801 E0.79987*93
    16:43:34.704 : Resend: N102 G1 X-16.927 Y-9.126 E1.00013*85
    16:43:34.704 : Resend: N103 G1 X-17.555 Y-10.642 E1.09813*96
    16:43:34.704 : Resend: N104 G1 X-18.553 Y-11.942 E1.196*109
    16:43:34.708 : Error:Tu:
    16:43:34.708 : Resend:100
    16:43:37.719 : Warning: Seems like we missed a ok, got a wait - continue sending.
    16:43:37.719 : Resend: N105 M117 ETE 5h 49m 05s*63
    16:43:37.719 : Resend: N107 G1 X-19.858 Y-12.944 E1.29426*105
    16:43:37.719 : Resend: N108 G1 X-21.375 Y-13.573 E1.39233*99
    16:43:37.719 : Resend: N109 G1 X-23 Y-13.787 E1.49021*112
    16:43:37.719 : Resend: N110 G1 X-24.624 Y-13.573 E1.58803*96
    16:43:37.724 : Error:Tu:
    16:43:37.724 : Resend:100
    16:43:37.731 : Resend: N100 M117 ETE 5h 49m 06s*57
    16:43:37.731 : Resend: N101 G1 X-16.491 Y-5.801 E0.79987*93
    16:43:37.731 : Resend: N102 G1 X-16.927 Y-9.126 E1.00013*85
    16:43:37.731 : Resend: N103 G1 X-17.555 Y-10.642 E1.09813*96
    16:43:37.731 : Resend: N104 G1 X-18.553 Y-11.942 E1.196*109
    16:43:37.735 : Error:Tu:
    16:43:37.735 : Resend:100
    16:43:40.749 : Warning: Seems like we missed a ok, got a wait - continue sending.
    16:43:40.749 : Resend: N105 M117 ETE 5h 49m 05s*63
    16:43:40.749 : Resend: N107 G1 X-19.858 Y-12.944 E1.29426*105
    16:43:40.749 : Resend: N108 G1 X-21.375 Y-13.573 E1.39233*99
    16:43:40.750 : Resend: N109 G1 X-23 Y-13.787 E1.49021*112
    16:43:40.750 : Resend: N110 G1 X-24.624 Y-13.573 E1.58803*96
    16:43:40.754 : Error:Tu:
    16:43:40.754 : Resend:100
    16:43:40.761 : Resend: N100 M117 ETE 5h 49m 06s*57
    16:43:40.761 : Resend: N101 G1 X-16.491 Y-5.801 E0.79987*93
    16:43:40.761 : Resend: N102 G1 X-16.927 Y-9.126 E1.00013*85
    16:43:40.761 : Resend: N103 G1 X-17.555 Y-10.642 E1.09813*96
    16:43:40.761 : Resend: N104 G1 X-18.553 Y-11.942 E1.196*109
    16:43:40.765 : Error:Tu:
    16:43:40.765 : Resend:100
    16:43:43.777 : Warning: Seems like we missed a ok, got a wait - continue sending.
    16:43:43.777 : Resend: N105 M117 ETE 5h 49m 05s*63
    16:43:43.777 : Resend: N107 G1 X-19.858 Y-12.944 E1.29426*105
    16:43:43.777 : Resend: N108 G1 X-21.375 Y-13.573 E1.39233*99
    16:43:43.777 : Resend: N109 G1 X-23 Y-13.787 E1.49021*112
    16:43:43.777 : Resend: N110 G1 X-24.624 Y-13.573 E1.58803*96
    16:43:43.781 : Error:Tu:
    16:43:43.781 : Resend:100
    16:43:43.788 : Resend: N100 M117 ETE 5h 49m 06s*57
    16:43:43.788 : Resend: N101 G1 X-16.491 Y-5.801 E0.79987*93
    16:43:43.788 : Resend: N102 G1 X-16.927 Y-9.126 E1.00013*85
    16:43:43.788 : Resend: N103 G1 X-17.555 Y-10.642 E1.09813*96
    16:43:43.788 : Resend: N104 G1 X-18.553 Y-11.942 E1.196*109
    16:43:43.792 : Error:Tu:
    16:43:43.792 : Resend:100
    16:43:46.802 : Warning: Seems like we missed a ok, got a wait - continue sending.
    16:43:46.803 : Resend: N105 M117 ETE 5h 49m 05s*63
    16:43:46.803 : Resend: N107 G1 X-19.858 Y-12.944 E1.29426*105
    16:43:46.803 : Resend: N108 G1 X-21.375 Y-13.573 E1.39233*99
    16:43:46.803 : Resend: N109 G1 X-23 Y-13.787 E1.49021*112
    16:43:46.803 : Resend: N110 G1 X-24.624 Y-13.573 E1.58803*96
    16:43:46.807 : Error:Tu:
    16:43:46.807 : Resend:100
    16:43:46.814 : Resend: N100 M117 ETE 5h 49m 06s*57
    16:43:46.814 : Resend: N101 G1 X-16.491 Y-5.801 E0.79987*93
    16:43:46.814 : Resend: N102 G1 X-16.927 Y-9.126 E1.00013*85
    16:43:46.814 : Resend: N103 G1 X-17.555 Y-10.642 E1.09813*96
    16:43:46.814 : Resend: N104 G1 X-18.553 Y-11.942 E1.196*109
    16:43:46.818 : Error:Tu:
    16:43:46.818 : Resend:100
  • What I see is that you have echo enabled which puts extra load on serial connection that is not necessary.
    Also the log is incomplete. You need the log written to work directory (if enabled) to see full communication. All I see here is
    Error:Tu:
    which I have never seen before and that somewhere a resend was triggered, but it is not visible where or why.
    We haven't change the communication handling. Could it be that the receive buffer length is larger then 127 set?
