Velocity Painting
It would be great if you could integrate Velocity Painting in to Repetier Host.
https://www.velocitypainting.xyz/blog/
  • Wow, I come home from work and get a pop-up saying version 2.0.1 is available.
    And right on the top in the changes log it says Velocity Painting.
    Very nice :-)
  • Yes after reading the page I wanted to test it, but the script did not work with slic3r g-code so I wrote my own solution:-)
  • But I can use the Cura slicer as well. Correct?
  • I think so. We have no special things as we had the advantage or using our existing gcode analyser to implement it and not fancy regular expressions that only work when matched.
  • OK, I will experiment. I'm getting great results with the original code and the Cura slicer.
