cant get my hot end higher than 160
i have been trying to get my new e3d hot ends working and they were heating up fine but not recording the correct temp.
now i can't get them above 160 degrees
the seem to try to carry on heating but slow down in the 150 area and level out at 160 to 165 and even tough im asking it to go to 200 it can't get there.
i am running a MPX.3 board and i have tried all 3 versions of the firmware
  • In host check temperature graph. If it is heating 100% your hotend has not enough power or is using wrong thermistor so that it is already much hotter. If not 100% you can increase max pid drive up to 255 in eeprom settings. This is often limited in basic configuration to a lower value.
