Delta Printer (Self made)
Hi I have a problem with my delta printer.
I try to solve it since a week no idears any more blease help.
All is running perfect, till i like to have a Z Probe sensor.
If I configr  the Firmware with this z probe sensor my prints are not paralel to the ground.
And Im mean not 1mm it is mor 1 cm ist starts on the ground and lift up by printing.
I also Delete the eprom with  M322 also deactivate with M321.
then I delete the matrix G33 R0.
Also with M502  no chance.
So it is a capacitor sensor. It work fine If I drive manualiy it is no Problem the Printer runs fine over the Ground.
Pleas give me some Idears how I can solve the Problem.
Thanks.
  • G33 is to remove last distortion and is not autoleveling. Use G32 S2 first and see what it does. That is the autolevel function and only after that is working and modifying geometry variables like e.g. suppsed by "escher delta calibration" 6 point version you should start using G33 if it is still not good enough. Also have you calibrated endstops at top like we describe in our tutorial for z probe?
    Apperently you do something wrong but since you do not say what you do and where it starts to go wrong I can just say check z probe manual on our homepage.
    And always be carefull and close to reset button as wrong settings can cause bad moves!
