Issues with Delta Homing
I've been having trouble homing my deltabot with firmware assembled on the configuration tool for a ramps motherboard. Once an endstop has been actuated by one of the 3 arms, all three motors disable and the homing sequence fails. Is this a common problem in the config?
thanks,
A
  • Normally it would hit all 3 endstops and then all go back. You need to go back enough to not trigger endstops any more. And after last retest you need to go down enough that selection of extruder is possible and endstops are also not triggered.
    Check what log is saying and also test M119 if one or more endstops are hit and if it is correct. Not that one hit triggers all endstops.
