Server Firmware max travel distance
Does the Firmware or Server actually limit the max travel distance?
    Server sends what you say. It is up to firmware to limit this. Our firmware just ignores moves outside print area but you need to be homed so it is correct. In dev version you can therefore also prevent moves until homed.
    Server tries to prevent moves outside if using the normal controls.
