Why is it not able to use Slic3r 1.3.0 in Repetier-Host
Hello
I habe instaled Repetier-Host on a fresh Windows 7 64 Bit
I want to integrate Slic3r 1.3.0 into it but slicing want work. Only the GUI from Slic3r starts an use some default settings. If i close slic3r this wauld be displayed:
16:04:35.635 : Slic3r command:C:\Program Files\Repetier-Host\Slic3r\slic3r.exe --load "slic3r_settings.ini" --print-center 95.00,95.00 -o "composition.gcode" "composition.amf"
16:04:41.455 : Info about composition.amf:
16:04:41.463 : size: x=51.230 y=45.210 z=25.007
16:04:41.464 : number of facets: 46708
16:04:41.464 : number of shells: 1
16:04:41.464 : volume: 10459.944
16:04:41.464 : needed repair: no
16:04:45.997 : Slic3r installed in a loclized path. Using an 8.3 path: "C:\PROGRA~1\REPETI~1\Slic3r\"
sorry for my bad english iam only german.
  • You need to reference slic3r-console not slic3r for 1.3.0. Also 1.3.0 needs some special care as things have changed. The upcoming 2.0 release knows how to handle this and has a version selector for that release.
  • thanks it works.
