Extruder travel limited to 160mm?
Hello!  I'm using Repetier host to control a custom manufacturing setup, and due to needing to independently control four steppers, I'm using the G1 E command for the fourth motor.  However I've found if I do a move of more than 160 mm, say G1 E161, nothing happens, it will not move.  For the life of me I can't figure out what's going on.  Any ideas?
Thanks!
Jesse
  • Its a saftey setting in firmware, under tools in the firmware configuration, or
    EXTRUDE_MAXLENGTH
  • Thanks Martin!  That's a life saver.
    Jesse
