Configuring particular LCD screen
How to configure this particular LCD screen: BT7262A V2016.10.12
  • Can anyone help i am using the reptier software
  • Don't know that display. Does it have a compatible chipset? Then adjust a display using that chipset and fix pin number in ui.h or DisplayList.h if using dev version.
  • How about this: LCM2004A1 (V1.0)
  • From the name it sounds like a standard 20x4 line char display. If iot uses the standard compatible chip it should work like the others so just set your pin numbers accordingly.
