Printer not priting
Hi, I've recently purchased a new board for my printer, and everything works, including manual control, however when I come to print it, it moves to the endstops but doesn't print, but it says so on the repetier host.
I am getting this error
11:24:50.849 : Error:Printer set into dry run mode until restart!
As well as:
11:24:59.203 : Other:: working marked decoupled
Any suggestions?
  • does the hot end and bed heat up correctly if you turn them on in the host
    Yep, When I print they heat up
