The firmware does not allow to print objects of more than 500 mm
The extruder is not pushing plastic, if the line in G-code is not broken and more than 500 mm. the lines Are just skipped, others print fine. The normal model, without duplicates vertices and other things. Did stripes of different lengths: 500, 550, 600, 650, 700, 750, etc Made the G-Code. Plastic presses only on the line 500. Somewhere in the firmware is some limitation I suppose. If the model is complex and consists of many polygons, curves etc., i.e., a model face not more than 500 mm, all prints OK. Tell me where this limit is in the firmware.
Please.
  • In config tool you set the max. extrusion length in "Maximum extrusion length / EXTRUDE_MAXLENGTH". This is to protect for big rewinds/extrusions when you forget G92 E0 and have big E value from previous print.
  • Thank you, as will test - will tell you about it))
    Thank you!!
  • All the best to you!
