Problem compiling Repetier firmware in Arduino IDE
I am a newbie to 3D printers and have started making my second one. I have no professional education in electronics/mechanics/etc. I am an amateur and working this out as a part of my own project.
I had once successfully made a 3D printer with the Repetier firmware (about an year  ago) but it had certain mechanical issues so I decided to make a new one.
This time, all went well until I tried to upload a new firmware. When I configured the firmware using "Repetier-Firmware configuration tool for version 0.92.9 version" and downloaded it, I tried to compile it using Arduino IDE.
It gave the following errors:
Eeprom.cpp: In static member function 'static void EEPROM::initalizeUncached()':
Eeprom.cpp:471: error: expected primary-expression before ')' token
Eeprom.cpp:509: error: expected primary-expression before ')' token
Eeprom.cpp:510: error: expected primary-expression before ')' token
Eeprom.cpp:511: error: expected primary-expression before ')' token
Eeprom.cpp:512: error: expected primary-expression before ')' token
Eeprom.cpp:513: error: expected primary-expression before ')' token
Eeprom.cpp:514: error: expected primary-expression before ')' token
Eeprom.cpp:515: error: expected primary-expression before ')' token
Eeprom.cpp:517: error: expected primary-expression before ')' token
Eeprom.cpp:518: error: expected primary-expression before ')' token
Eeprom.cpp:519: error: expected primary-expression before ')' token
Eeprom.cpp: In static member function 'static void EEPROM::readDataFromEEPROM(bool)':
Eeprom.cpp:725: error: expected primary-expression before ')' token
Eeprom.cpp:726: error: expected primary-expression before ')' token
Eeprom.cpp:727: error: expected primary-expression before ')' token
Eeprom.cpp:728: error: expected primary-expression before ')' token
Eeprom.cpp:729: error: expected primary-expression before ')' token
Eeprom.cpp:730: error: expected primary-expression before ')' token
Eeprom.cpp:731: error: expected primary-expression before ')' token
Eeprom.cpp:735: error: expected primary-expression before ')' token
Eeprom.cpp:744: error: expected primary-expression before ')' token
Eeprom.cpp:745: error: expected primary-expression before ')' token
Eeprom.cpp:746: error: expected primary-expression before ')' token
I tried with Arduino IDE 1.6.11 as well an older version 1.0.5, however both gave similar errors.
I have to do a lot ahead - checking stepper motors, checking end-stops, other electronics (LCD, Heated bed, extruder, etc.).
Please help me.
    Could it be that you changed EEPROM.h? That is strictly forbidden for non programmers:-)
    Start with original sources or bette ruse our config tool to configure,then it normally compiles (unless you use undefined pins).
