configuration problem
Hi
I have a configuration problem.
In my printer printbed it moves in a vertical axis. To get started the printbed print must arrive at the head and make every layer go down.
Now after every layer the printbed moves up and doesn't go to print.
Can I change the option to print correctly?
  • Invert direction for z motor or rotate motor connector 180 deg.
