Fatal error
Printer with Repetier 0.92.9 Firmware.
If I change Firmware in Repetier Server Settings from Marlin to Repetier I get fatal error.
I have 2 other printers with Repetier Firmware working.
What's wrong ?
  • Sure that printer uses Repetier-Firmware as well? Using repetier on non repetier firmware will not succeed. M115 in marlin modemshould show what is really on printer. If it is repetier-firmware explain what is fatal error.
  • This is what M115 shows:
    19:43:50.714: FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    19:43:50.722: Printed filament:132.35m Printing time:1 days 11 hours 25 min
    19:43:50.722: PrinterMode:FFF
  • I use RADDS 1.5 with Arduino Due
  • Ok it is then repetier-firmware. So now describe the error you get. I mean how should i help if you just say you get an error without saying what.
  • edited March 2017
  • Please enable lighing and check the log what is exactly going wrong. Maybe wrong buffer length in connection setting.
