Z-axis stepping issues
Q3 ThreeUp V3 printer. Arduino 2560 and Ramps 1.4.
X and Y axis move correctly under manual control and print correctly and to scale.  The Z axis has 2 NEMA 17 stepper motors and twin screws.  When I manually press the Z-Axis 0.01 button the Z-axis moves on average 0.1 mm.  When I press the Z-Axis 0.1 button the Z-axis moves on average 1.1mm.  If I press the Z-Axis 1.0 button the z-axis moves momentarily and then stops and the motors make a whining sound.
The stock configuration is:
#define DEFAULT_AXIS_STEPS_PER_UNIT   {88.88888888889,88.88888888889,1511.811023622047,88.57326053533955}
#define DEFAULT_MAX_FEEDRATE          {500, 500, 5, 45}
#define DEFAULT_MAX_ACCELERATION      {5000,5000,100,10000}
#define DEFAULT_ACCELERATION          5000
#define DEFAULT_RETRACT_ACCELERATION  5000
I have played around with these numbers and have had no luck to get the Z-axis to move to scale:
11:27:52.344 : echo:  M92 X88.89 Y88.89 Z1511.81 E88.57
11:27:52.345 : echo:Maximum feedrates (mm/s):
11:27:52.347 : echo:  M203 X500.00 Y500.00 Z2.00 E45.00
11:27:52.348 : echo:Maximum Acceleration (mm/s2):
11:27:52.351 : echo:  M201 X5000 Y5000 Z6 E10000
11:27:52.354 : echo:Accelerations: P=printing, R=retract and T=travel
11:27:52.355 : echo:  M204 P5000.00 R5000.00 T5000.00
11:27:52.363 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s),  Z=maximum Z jerk (mm/s),  E=maximum E jerk (mm/s)
11:27:52.366 : echo:  M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
  • Firmware is just configured wrong. Correct z steps per mm and it should be ok.
  • I have modified the z steps from 1151.81 to 50% at 573.18 and it did nothing.  When I double the z up to 2560 the stepper motors whine and don't move at all.
  • Also, when I print a 20mm calibration cube, it prints perfectly in X and Y but is 40mm in Z.
  • check your jumpers under the Z driver?
  • edited March 2017
    As roko said , allso
    What type of Z screws are fitted, ie  5mm thread rod or 8mm or 4 start lead screw ?
    This helped tremendously.  The original kit did not have jumpers under the z-stepper.  I added 3 jumpers for MS1, MS2 and MS3 and the print quality went way up.  The 20mm cube went from 40mm in the z-axis to 15mm.  I pulled the MS3 jumper to reduce to 1/8 microstepping to see if that would get the z to 20mm but it went over 20mm.  So I will keep all three jumpers but I am not sure how to get the cube back to 20mm.  Maybe layer height?
    Well, I cannot tell.  The kit decided to leave out that important information.  Outside measures 10mm, inside threads is 8mm and there are 13 threads per inch (well more or less).
  • Fixing z steps per m is the only way to fix the last difference. Can not say how to do this correctly with marlin. Normally i would just change it in config and reupload. If they do not use it from eeprom it should suffice.
  • edited March 2017
    From what I recall, using Rep-Host  with Marlin, under config - firmware you can change steps/mm and save to EEPROM. The screen is a little different. I would also change the configuration file to the new steps so if you reload firmware you won't have that problem again..
  • edited March 2017
    From looking at the kit details  i would say you definitly have 4 start lead screws on the Z axis, so you will
    most likely need 400 steps/mm with a max feedrate of about 30. You should be able to edit these in the eeprom
    via rep host.
    Allso, leave the 3 jumpers installed for 1/16 microstepping
  • from your description it´s a TR 10x2 thread  and it will need 1600 steps /mm  at 1/16 microstepping with a 200 steps/rev motor
    Thanks, that worked good.  I determined the % out the 20mm cube was in the Z axis and applied that to Z steps and it came out almost perfect.  All of this was done through RH.  For anyone else with this problem:  go to G Code line and type in M501 to see what the current settings are for the all of the steps.  They are shown on line M92.  Type in M92 Z***** (where the ***** are the steps you have calculated) then hit enter.  Then type in M500 to save it.  Then type in M501 to confirm the setting change.
    Yes, after working through the calculations, 1537.66 works pretty good and is very close to your recommendation of 1600.
    via rep host.
    I will look at these settings to see how it performs
