LCD 12864 blocks COM port when attached
Hi
My 3D printer is up and running when I use a computer to send G code.
I have used Repetier config tool and assigned Reprapdiscount full Graphics controller 128*64 RAMPS..
I get #define FEATURE_CONTROLLER 11 in the configuration.H file.
When I attache the LCD to the MB the COM port is lost. A soon as I de attache the LCD it works again.
My configuration is: SainSmart Ramps 1.4 + Mega2560 R3 + LCD 12864 3D Print Controller Kit For RepRap
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 1
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_ANIMATION 1
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
What can be the problem?
Do I need the U8glib, if so, how to install them?
