Mac OS 10.6 Issues
On the Mac OS 10.6.8 the installer runs fine. However there are two bugs:
- Nothing appears in the dashboard (even after rebooting)
- http://localhost:3344 does not work
-- error message is "Safari can't open the page "http://localhost:3344/" because Safari can't connect to the server "locatlhost"
-- http://localhost works fine.
From the unix command line, sending the 'load' command as detailed in the documentation says that it is "Already loaded". Loading & unloading have no effect.
Scanning the ports, there is nothing listening to 3344.
  • So it looks like at least launchd is working, but some other part is different then on Yosemite that causes it not to run.
    Installer uses
    /usr/bin/dscl
    to create the user repetierserver which is used to run the server. Doc is from 2003 so I assume you have it as well?
    In /Library/Application Support/Repetier-Server/logs you should find a server.log file that might give a hint.
    To see if server is running execute
    ps aux | grep tier
    RepetierServer     29   0,0  0,0  2479384   4096   ??  Ss   So07pm    0:06.76 /usr/local/Repetier-Server/bin/RepetierServer --config=/usr/local/Repetier-Server/etc/RepetierServer.xml
    hope that one of the hints show what is different on 10.6.8
