Configuration tool for version 1.0.0dev doesn't compile any more?!
I tried different settings (with zprobe and without) and also started from scratch without uploading an existing configuration.h file. Always downloaded the entire zip file at the configuration tool and get following fault when I compile it.
Arduino: 1.0.6 (Windows NT (10 Pro)), Board: "Arduino Mega 2560 or Mega ADK"
In file included from /Repetier.h:1048,
                 from BedLeveling.cpp:107:
Drivers.h:105: error: ISO C++ forbids initialization of member 'position'
Drivers.h:105: error: making 'position' static
Drivers.h:105: error: ISO C++ forbids in-class initialization of non-const static member 'position'
BedLeveling.cpp: In static member function 'static bool Printer::startProbing(bool)':
BedLeveling.cpp:472: error: 'deltaMaxRadius' is not a member of 'EEPROM'
Two days ago it was working though. Has there been a change?
Thanks for any input.
Martin
Copied the relevant portion of Configuration.h below.
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 255
#define Y_MAX_LENGTH 205
#define Z_MAX_LENGTH 225
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define Z2_MINMAX_PIN -1
#define DISTORTION_END_HEIGHT 2
#define DISTORTION_XMIN 0
#define DISTORTION_YMIN 40
#define DISTORTION_XMAX 250
#define DISTORTION_YMAX 200
// ##                           Movement settings                                          ##
#define BABYSTEP_MULTIPLICATOR 4
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 5
#define HOMING_FEEDRATE_X 50
#define HOMING_FEEDRATE_Y 50
#define HOMING_FEEDRATE_Z 3
#define HOMING_ORDER HOME_ORDER_XYTZ
#define ZHOME_PRE_RAISE 1
#define ZHOME_PRE_RAISE_DISTANCE 4
#define ZHOME_HEAT_ALL 0
#define ZHOME_HEAT_HEIGHT 5
#define ZHOME_X_POS 120
#define ZHOME_Y_POS 100
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1750
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1750
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 1750
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1750
#define MAX_JERK 12.5
#define MAX_ZJERK 0.3
#define PRINTLINE_CACHE_SIZE 32
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define Z4_STEP_PIN   ORIG_E3_STEP_PIN
#define Z4_DIR_PIN    ORIG_E3_DIR_PIN
#define USE_ADVANCE 1
#define ENABLE_QUADRATIC_ADVANCE 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 2
#define Z_PROBE_PIN 45
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET -7
#define Z_PROBE_Y_OFFSET 40
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 0.8
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 3.2
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 10
#define Z_PROBE_Y1 40
#define Z_PROBE_X2 250
#define Z_PROBE_Y2 40
#define Z_PROBE_X3 10
#define Z_PROBE_Y3 200
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
  • Nobody else having this problem with 1.0.0 dev?
    I might have found the root cause. Looked up my last version that was working from 4 days ago and found in the new version following lines that were different
    Drivers.h
    int32_t position = 0;
    Bed_leveling.cpp
    #if DRIVE_SYSTEM == DELA
    When I change it to
    int32_t position
    #if DRIVE_SYSTEM == DELTA
    it compiles. Haven't uploaded and tested it yet.
  • Thanks for the hint. Have fixed it now. Not sure why it compiled for me correctly for delta.
    The position = 0 initialization should be no problem with recent compilers, but I have changed it back to initialization in constructor for old C++ compilers. So now it should compile fine.
  • Thanks, that was quick.
